2004 Forester X
Had some front end damage, But i think most of that is cosmetic..
radiator support got a bit of a wrinkle around the headlight, hopefully it doesnt cause to much trouble to fix
Already went junkyard hopping and got all new replacement parts (that match my paint =-o)
Fender fit quite well,
hood already has a dent in it :( and havent quite figured out the alignment (it doesnt hit the hood latch)
but, i'll get it!
Next up, bumper!
Reactions: Daniel333
Vendor
Hi and welcome to the forum! Thanks for joining us and showing your Subaru. A lot of good info here regarding mods in case you are thinking of doing any. Check out some of the garages and you may get some ideas. Come back often and post up your progress!
2010 Forester 2.5 XPremium 4EAT
Hi & welcome!
Following your progress.
What's the motor like, does it run well?
2004 Forester X
After another Trip to the junkyard for the interior bumper (it was more bent than i thought) and to get a new headlight (clips were broken on the other one) and to return the hood (couldn't get it to align, figured it could be a fight for another day...
I got the car put back together. Its not perfect, but its all together!
522754
522755
2004 Forester X
Hi & welcome!
Engine seems good. I got it from the second owner, who did extensive maintenance on it. It's at 194,000 and he did brakes, tires, timing chain, radiator, some oil gaskets, and a couple other things in the last 5 years.
I think it needs a right rear hub or bearing, and i need to get the AC working.
2004 Forester X
