1 - 12 of 12 Posts
USDM 2007 Subaru Forester XT Sports OBP JDM Legacy 6-Speed
Purchased new from Sierra Autocars on September 6, 2007. Options STi short shift 5MT and rear wing.
Mod list
Power 326/326 on 91 octane
Engine
Manley forged pistons and connecting rods
ACL main/rod bearings
Orbit oil pump
Killer B oil pickup
Walbro 255 fuel pump
Cobb/ID 1050 injectors
NGK 1 step colder plugs
OTL performance coil packs
Swaintech coated Tomei uel/up pipe
Z/S JDM length catted DP
Blitz Nur spec-r catback
Z/S intake
Perrin Turbo inlet
3-port BCS
Cobb accesssport v3 protuned
Blouch TD06H-20G XT turbo
PTP turbo blanket
Process West TMIC
HKS SSQ BOV
Koyo radiator
Forge Motorsports overflow tank
Samco sport lower hose
Cosworth 1.5 bar caps
Avo catch can
Motul 5w40
Transmission drivetrain
JDM 2006 Legacy Spec-b 6-speed TY856WVCAA R160 3.90 no-dccd
WPC treated gears and shafts
OEM STi flywheel
ACT h/d clutch pressure plate
Cusco front and center lsd
Kaaz rear lsd
Arashi Dynamics rear diff cover
USDM STi shift linkage
Modified OEM 5-speed driveshaft
Beatrush transmission mount
Beatrush transmission crossmember bushings
Beatrush front shifter bushing
Torque solutions shifter pivot bushing
Faction fab rear shifter bushing
Cusco/Kaaz/Motul oil
Suspension chassis
Tein Super Flex Wagon overhauled coilovers
Tein EDFC
Whiteline 22mm sway bars
Whiteline End links klc139
Whiteline Lateral links
Whiteline H/D sway bar mounts
Whiteline steering rack bushings
Whiteline sway bar lateral locks
Cusco rear subframe brace
Cusco lower arm bar type 2
Cusco power brace engine room
Cusco power brace floor rear
Cusco OS rear strut bar
Whiteline subframe lock kit
STi FHI front titanium strut bar
Cusco power brace rear trunk
STi front aluminum control arms
Ikeya formula tie rod ends
Ikeya formula roll center adjuster
Jspeed fender braces
Whiteline rear diff outrigger bushings
Beatrush forged pitch stop
Wheels and Tires
5x100 Volk G25 18X9 +45 Formula Silver
Michelin Pilot Sport 4 S 235/45/18
Brakes
Stoptech 4-piston/2-piston bbk
Cusco bcs
Motul RBF600 fluid
Exterior
Liberal albero front bumper
Stage21 carbon lip
STi lip skirt
Liberal side skirts
Liberal rear bumper
Wangan-spl waist garnish
Chargespeed carbon hood scoop
Beatrush skid plate
Depo 08 sports headlights
Depo led tail lights
Interior
Blitz 60mm boost and egt gauges
Blitz 52mm oil pressure and oil temperature gauges
Aem 52mm afr gauge
Beatrush titanium shift knob/aluminum reverse lockout
Razo pedals
Broadway rear view mirror
ICE
Alpine cde-hd149bt head unit
Alpine rux-c800 dsp controller
Alpine pxa-h800 dsp
Alpine pdx-v9 amplifier
Focal elite k2 powr es 165k components
Helix esprit e8w 8-inch subwoofer
Past/future/pending mods
5x100 Prodrive GC-010G 18X7.5 +48 wheels (replaced with Volks)
Whiteline endlinks klc-32 (replaced with klc139)
OEM Sports bumper (sold/replaced with Liberal bumper)
Z/S carbon grill (sold/replaced with Liberal bumper)
Cusco lower arm bar version 1 rear (won't fit with rear diff cover)
Bride Zeta 3 plus carbon aramid (ETA 2/2020)
Hardrace pillow ball bushings and tie rods (next alignment)
Liberal Albero front bumper stage21 carbon lip STi lip skirt
527963
Liberal SG side skirts Liberal SG rear bumper Wangan-SPL waist garnish
527964
2006 JDM Legacy spec-b 6-speed zero/sports jdm length catted dp
527966
Beatrush Type-e titanium shift knob aluminum reverse lockout
527967
Discussion Starter #7
Tein super flex wagon Ikeya formula tie rod end roll center adjuster STi aluminum control arm
527968
Discussion Starter #8
Whiteline kta127 lateral links 22mm adjustable sway bar cusco sub frame brace power brace floor rear
527969
Discussion Starter #10
Re-built axles being installed in the front. Having a clutch type LSD in the front that makes a similar noise to a bad axle clunk makes it harder to know when to replace.
528843
1 - 12 of 12 Posts
