1 - 20 of 20 Posts
MY01 Forester GT 6MT
Gday everyone my names Jacob and i thought i would introduce my forester.
Ive owned it since early 2011 originally as a dayily drive to get to to my apprenticeship, but as i got qualified a company car came along with it and need for the foz was gone ..... so i turned it into a race wagon!!
Coming up to 8 years on its now sitting at 400kw and gets raced a couple times a month 馃檪
Engine :
Bosch 1650ccs
06 spec c big port heads ..with extra porting and polish
T20c 207 been closed decked
Bc 274/278 avcs cams
Bc hd valve springs
Ferra 6000 1mm oversize valves
Later model spec 207 block
Oil phased 79mm stroke crank
Argo I beam rods
Je 92.5mm forged stroker pistons
Cozzy 1.1 mm head gaskets
Arp 625+ studs
Liberty gt sump
Killer b oil pick up
Killer b baffle plate
Turbo smart 40mm gate
6boost steampipe wrx to t3 twist adaptor
Garrett bb gtx3076 .82 rear with 4in antisurge front housing
Kando el headers
Custom 3" straight thru exhaust with x-force cannon
04 sti manifold with tgv deletes poet matched and manifold pnp
Fmic with custom pipes to suit rotated intake manifold
Driveline/ underbody:
2010 Japanese short ratio 6mt dccd gear box
R180 axles
3:54 r180 plated LSD rear diff
06 sti 114.3 hub conversion
Torsen LSD front diff
V6 Ra quick steering rack
Hsd inverted mono pro coilovers
Gold brembos all round
White line 22 and 24mm sway bars
White line rear control arms
Sti alloy front control arms
V6 sti genuine front strut brace
Exterior:
Full Foz type c sti body kit
5eigen 17x8 +30 wheels
Genuine Gannador mirrors
Dark tint on rear
02 sti style scoop
Custom mesh grill with f badge
Interior :
Omp first R fixed back drivers seat
Sparco fixed back passenger
Turn one hans point harness
Rpm 3" 6 point harness passenger
Weld in half cage
Billet 150mm shifter
Rpm corse steering wheel
Forester sti handbrake
Triple gauge cluster in centre of dash
V6 Ra dash with dccd lights
Electrics:
Link g4+ xtreme
Dccd pro universal gearbox controller
2003 JDM Cross Sports
Excellent stuff! I used to do tarmac rallying and rally sprints a few years ago now and that footage reminds me of some of the stages I used to run on, except you're going a lot faster!! That said, my Peugeot 205 had 300bhp less and only 2-wheel drive! :wink2:
Interested why you haven't fitted a full roll-cage or is that on the jobs to do list?
Discussion Starter · #10 ·
Update my forester now has a full 6 point national rally spec safety cage 馃檪
Discussion Starter · #14 ·
Discussion Starter · #18 ·
so after nearly 3 years of 500+ hp and many many kms of race use it was past due to pull my engine down for an inspection firstly and then a refresh!! so far I've done the tear down part will drop it off to the engine shop tomorrow for a 2nd opinion and required touch ups in machining :) some pics of findings..
72326500_640177306509818_2731356654862860288_n by jacob ayres
72437365_523353958518146_6203198605365346304_n by jacob ayres
72402876_737850183397714_7430125695017156608_n by jacob ayres, on Flickr
73083644_2249230261855428_2640012364153356288_n by jacob ayres, on Flickr
73079635_442564749715912_6212200852522795008_n by jacob ayres, on Flickr
72546973_443380862951402_4987804679724335104_n by jacob ayres, on Flickr
72726316_2414528162199282_6286795032770904064_n by jacob ayres, on Flickr
72231930_505137546730953_2135156898586951680_n by jacob ayres, on Flickr
72246643_435324626981470_8285575153362927616_n by jacob ayres, on Flickr
72108136_680686542456435_1110746617977241600_n by jacob ayres, on Flickr
Discussion Starter · #19 ·
Goodies ordered this week , boosted performance parts have hooked me up with new xtreme clutch, intima type D V2 pads, rcm head gaskets, genuine gasket kit, water pump and timing belt kit :)
Long block is with the engine shop for testing and once over of everything then bob (my co driver) and i will reassemble :)
1 - 20 of 20 Posts
