Ok, I'm now to the point I want to rotate my tires at home since the guys at the tire store seem to strip out the lugs.
I've got a floor jack and 2 stands. I can see the jacking point for the OEM jack and I have tried using this along with a block of wood. I can get the car high enough but to find a decent place to put the stand. The recommended place to put the stand is so close to the jacking point that it ain't gonna work.
I tried using the read diff but it raises the tires fine but not the car high enough to get the jack stand into the sweet spot, and since I'm swapping tires F & R same side I can't see the logic in spending too much time in the rear diff method.
So, anybody run into this b4 and have a solution? thanks
