You need to move. Maybe Central New York (Syracuse)remal said:never had more than 2" of snow in 15 years. I want some now
Probably got high-centered from pushing snow. I did that in our Outback 3 years ago. It wasn't a traction problem, it was a wheels-are-no-longer-fully-on-the-ground problem. I had to dig out the front end quite a bit. Once the car's weight was back on terra, er, snowy firma, we were fine again.sschmelcke said:i actually got stuck today in about 15 inches of snow. had all 4 wheels spinning mad
If its not too bad, you can get out by rocking the car side to side. Push up on the door frame, and let it drop. Just keep at it for a minute, and it will compress the snow a little bit, letting the wheels down.Seven said:Probably got high-centered from pushing snow. I did that in our Outback 3 years ago. It wasn't a traction problem, it was a wheels-are-no-longer-fully-on-the-ground problem. I had to dig out the front end quite a bit. Once the car's weight was back on terra, er, snowy firma, we were fine again.
Or the lazy mans way. Just let the car run and the heat will melt the snow.FXTIam said:If its not too bad, you can get out by rocking the car side to side. Push up on the door frame, and let it drop. Just keep at it for a minute, and it will compress the snow a little bit, letting the wheels down.
And driving what appears to be a Caterham version of Lotus's old Super Seven, you want to be careful what you wish for! The S7 was my adolescent fantasy car, still retained!remal said:never had more than 2" of snow in 15 years. I want some now
