2000 WRX
Hey,
I'm just after some info on upgrading my 440cc side feed injectors on my V6 Wrx motor. I was after a direct replacement.
Does any of the foresters come out with 550cc side feed injectors to suit my wrx motor?
Thanks
2004 FXT 5MT
04/05 comes with 500/550 side feeds, but your car may or may not run properly if you swap them in.
Now tell us about your V6 wrx motor :confused:
2004 fxt A/T
There is a lot of debate on what size the sidefeeds actually are in the 04-05 fxt's. They are at least 500's and depending on fuel pressure can surely run over 550cc. Now seriously tell us about this "v6 wrx motor".:huh:
Asphalt Surfers Unlimited
2004 Forester XT
The side-feed injectors in the '04 F-XT (yellow cap) are 100% identical to the yellow cap side-feeds in the '04 STi. They are the same part number.
The scaling in the factory mapping is ~503cc, and testing seems to confirm that figure at factory fuel pressures. Increasing pressure is possible, of course.
2004 Forester XT
Hey,
Thanks
Version6 side-feed injectors are a different style from the side-feed injectors in the USDM F-XT and STi. Sorry to burst your bubble. :(
2000 WRX
Discussion Starter #9
Hey guy's,
Yeah i meant Version 6 WRX MY00 (Aus Spec)
Reason being i wanted a direct replacement for my stock 440cc injectors since i have recently installed a Apexi Power FC ECU and want more power out of my ported VF35 Turbo and wanted a bit more head room with the larger injectors. I've just heard that maybe the later model foresters come out with larger sideifeed injectors which i could drop into my car.
