Hello all,
I have just purchased a magnaflow muffler with a 2.25inch tip. Question is , will I be able to remove the tip of a STI muffler and retrofit it to the magnaflow ?
Anyone had done this before here?
Cut the tip from here ......
and fix it to .....
The Sub kit guy
2005 Forester X & XT VF39
See the weld spot on the top? Drill that out and do the same to the one on the bottom (if there is one). To install it on the magnaflow you can spot weld it if you have the means, or use a stainless sheetmetal screw in each weld spot.
Hey sea-scooby, thanks for the reply.
Ok, let's say the tip is removed, but the exit from the muffler is 3.5 inches, where else the exit for the magnaflow is 2.25 inches.
How to go about that?
