1 - 7 of 7 Posts
2014 Forester XT Premium CVT
Hey Folks,
Trolling here for a few months now. I decided to check a few things tonight since I now have 4500k miles on my wifes 2010 forester N/A Prem PZEZ forester. I checked the fluid levels tonight just out of curiousity and every time I checked the ATF fluid it was high..above the high temp mark of dip stick (took about 10-15 samples) it was actually about the bend of the dipstick. Seems a little high for 80 F(ambient temp) with about 3 hours cooling since driving. The oil measured fine, the diff fluid good, but the tranny level seemed high. I though the bend in the tube maybe I was measuring high but I'm certain it's not user error. Is this possible for it to be delivered with 7 miles total from purchase? Also, the coolant seemed a bit dark? Is that the sealant additive? I was reading about HG trouble so thought I'd chech that.
thanks in advanced,
Ben
2007 2.5X 5mt
IF you check w/o the engine running the fluid runs out of the torque converter back into the tranny. Centrifugal force fills the torque converter with fluid.
It needs to be up to operating temp. You need to go through the gears slowly while the engine is running. And then wipe off the stick and check it..engine running in Park
1 - 7 of 7 Posts
