2019 Forester Sport
For folks with iPhones, I just learned today that there is a way to enhance the audio and Car Play connectivity to your headunit. If this has already been posted somewhere I apologize but couldn't find it.
1. Go into your "SETTINGS"
2. Select "MUSIC"
3. Select "CELLULAR DATA"
4. Turn on "HIGH QUALITY STREAMING"
I learned about this on my Acura Forum as a lot of folks, regardless of the vehicle manufacturer, have been experiencing Car Play hiccups that turning on this feature has resolved. I hope this helps you if you have experienced issues with your Car Play:wink2:
2019 Forester Touring CVT
For folks with iPhones, I just learned today that there is a way to enhance the audio and Car Play connectivity to your headunit. If this has already been posted somewttthere I apologize but couldn't find it.
2. Select "MUSIC"
Hi SG, I can't seem to locate "Music" under "Settings" in my Touring, with or without Car Play engaged, could you provide a few more details please.
2019 Forester Limited CVT
Thanks for the tip! I do get some playback hiccups with CarPlay and my iPhone 6S, so I'll try this and see if it helps!
2019 Touring (On Order)
If people use Spotify there are also settings.
A bigger secret: The Sirius XM iOS app also has quality settings, and sounds way better than the sound to the head unit due to less compression. It is just a little harder to navigate on screen.
2011 Forester Ltd 2.5
I'm surprised that using the setting which requires MORE data eliminates "hiccups". I would think the less data you're pulling, the smoother the broadcast would be (though at a lesser sound quality).
