1 - 8 of 8 Posts
2003 Forester 2.5XS (AT) 4-speed Automatic
Hi everyone!
I have a bit of a problem with my AC I'd like to ask about :icon_biggrin: .
My AC on my 2003 Forester XS Automatic seems to be working intermittently. Basically, what's happening is that the AC is ice cold for about 30 seconds to a minute, and then suddenly the AC stops and hot air gets blown into the cabin for 15 to 30 seconds. It's always present, but is much more noticeable at high speeds. I had a local (non-Subaru-specialist, but trusted) mechanic take a look at the AC, and he told me there was a slow leak in the coolant system.
However, following the advice of this other thread at <www subaruforester org/vbulletin/f88/intermittent-c-56793> about intermittent AC, I also took a look under my hood to see what the heck was going on, and sure enough, the symptoms seem very similar. The routine goes something like this:
(0 seconds) AC and radiator fan are chugging along merrily.
(+15 seconds) A very quiet hiss starts (only audible when the hood is open and I'm leaning over the engine)
(+30-40 seconds) I hear a relay "click", and the hissing noise stops.
(+40 seconds) The radiator fans come to a stop, and I heard the engine RPMs go up a little (possibly the AC compressor stopping?)
(+45 seconds) The cabin air goes from ice cold to hot very quickly, although the HVAC fan speed stays constant.
(+55-60 seconds) The radiator fans come back on (I hear the relay click again), and the AC comes back 10-15 seconds later.
This cycle repeats after 1 to 2 minutes.
So now I ask you...any idea what the problem could actually be? If it's a bad relay, how can I check it? If it's something else, what could it be? And should I worry about that hissing noise?
(Updated 5/24 for accuracy)
Here's another thread to check out:
Thanks!
Also if you have a feeler gauge, look at post #5, about the compressor clutch gap.
Hmm...don't have one, maybe I should go pick one up. I do know I'm not hearing any weird squeaks or anything of that nature, though.
2011 Forester XT Premium AT
Did you ever find out what happened? I'm going through the same thing with my 03 X @ 108K mileage. I have yet to take mine in yet, and it's getting in the upper 80's - low 90's now. I'll need to get it fixed soon.
Thanks..
Thanks!
I haven't quite figured it out yet...my trusted mechanic couldn't drive around for long enough to duplicate the issue.
Fortunately my sister also has a similarly equipped '03 XS and she'll be stopping by on Monday, so I think I'll steal her relays for a day and see if that fixes anything. :icon_razz:
2019 Crosstrek 2018 XT
Hard to troubleshoot AC without a set of gauges.
Discussion Starter #7
Okay, I tried swapping out every single one of the relays...and that proved inconclusive. I'm going to see if I can get a set of feeler gauges tomorrow.
1 - 8 of 8 Posts
