1 - 16 of 16 Posts
2004 2.0 X
I think I've found a aftermarket part number ADS72503?
Any recommendations from reputable UK online retailers? The interior glass of the car was very misted today. I think its time for a new one.....
Mad Englishman.
MY06 Forester STi 6MT
Seriously, I thought the "cabin air filter" was slang for winding the flippin' windows down. Hard Forester core my ***......
Get a face mask it's cheaper. In fact if you're got private medical insurance a new lung is cheaper.....
:mob:
Bunch of southern whoosies....
oh hang on....
2004 2.0 X
Discussion Starter #7
Wow, very easy to fit. Almost intuitive? I only glanced at the instructions on Pura website- found them confusing.
Observations? The bolt on the side- its screwdrive insert is almost chewing-gum soft!
Now- instead of just hearing the roaring warm air.....I can now FEEEL IT!
The insert itself was black with soot and very heavy with bits and pieces. Euck.
Thank you guys.
A
Guest
I just ordered one but now realise that they won't fit a MY00 SF will they? :crazy:
2004 2.0 X
Discussion Starter #9
Hmmmm. My windscreen was wet/damp again on the inside this morning. What do I need to do- any ideas?!!!
2015 XC diesel CVT
dry out whatever's wet and stop it from getting wet again...
seriously tho. Soggy carpet, dodgy sunroof drains or door seals, blocked a/c drain. check'em all.
2004 2.0 X
Discussion Starter #11
Will check under the bonnet around the bottom area of the windscreen/vents for leaves etc and down the sides for drain holes. blocked a/c drain- where is this located?
The inside of the windscreen is the worse-affected so Im guessing its the plastic-vent area where the problem is..
2015 XC diesel CVT
look for a hose coming out of the bottom of the heater and passing outside through the floor/bulkhead.
Thank you guys.
Hora, can you post the link to the website with fitting instructions please?
Cheers :)
2004 2.0 X
Discussion Starter #15
Ta/beaten to it. Didnt see that one! On step two just above the words 'filter cover' is a black box (ecu?) that has a single screw on it- you need to undo that first to get to the door/slide in/out the filter.
It really is easy though. Strangely alot easier than (faffing) changing the engine air filter.
Word of warning though- only attempt to do this on a dry day/not raining.
A
Guest
Just to let you all know I got an email from *** car parts telling me they now do a pollen filter to fit the SF for £12.50 but it's not on their website yet, he sent me that one and refunded the difference :woohoo:
1 - 16 of 16 Posts
