1 - 14 of 14 Posts
2005 2.5 x 5 speed manual
Im trying to start modding my car little by little.
my first goal is to put a RAM intake into my forester.
only problem I'm finding is that most vendors only sell RAM intakes (or any intakes for that matter) for turbo Foresters, which won't work with my MAF sensor.
Can anybody recommend any brands that would work on my Forester?
any other modding advice is appreciated too :)
I've read where some members have lost power by installing a CAI intake. :icon_eek:
A better & lower cost option may be to route cool air from the fender to the stock air box. :confused:
Im going for RAM because from what I understand RAM doesn't give as much power because the air is hotter, but since the pipe is shorter it gives more of a boost to my mid RPMs which is what I'm looking for.
Cold air would require a longer pipe, which while it would be denser air the difference wouldn't be felt until higher RPMs.
Am I correct to assume so?
2008 Forester X Premium 5MT
They can be a good way to actually lose usable power too.
A Problem with CAI/SRIs and an Alternative (yes, finally)
People often think they 'feel' a gain because there is a loss in the bottom end and mid range, then the upper mid and top end come back to normal. They perceive the increased pull of the top end coming on as a "gain", when the reality is they actually lost power in the bottom end and gained nothing at all.
Modding is fine, but one has to look at the whole picture of what is going on. More air flow doesn't always equal more power.
2017 VW Golf SportWagen 5MT
That looks like a short ram intake to me, it'll suck hot air from under the hood. Ram-air is considered a cold air intake and is supposed to scoop air from outside, no?
Stan
2002 ES300
Eh, maybe my terminology is off, that to me looks like an SRI with a box around it. If I were to do it, I'd route the tube through the fender, seal it and have filter in the fender well, I thought that's how CAIs worked on Subarus. I thought ram-air is when you have a scoop that catches more are as you go faster.
Stan
2002 ES300
Stan
I think you are technically correct too. (A lot depends on I guess if you are used to classic American muscle cars or the newer 'tuners'.) I generally drop the 'short' off of 'short ram air intake'.
If he wants to go the route you are referring to, he can do this: PRODUCT DETAIL | Gorilla Offroad Company But then he'll need a new hood and scoop, like off of an XT. But again, he'll need a retune for it to work (properly).
mothership - To which are you referring?
G
Your car is MAF based. The bottom line is that you'll lose power unless you get a tune for it.
1 - 14 of 14 Posts
