Find out how much it would cost to get oil temp monitored before you go and put a cooler on it.
Coolers arent of huge benefit unless you are absolutely hammering on the car - the stock 'cooler' on the wrx is more of a heat-exchanger with the water coolant system - intended to get oil up to temp quicker moreso than to take heat out of the oil.
Dont throw money at problems when you dont know what the causes are - or youll be chasing problems without understanding why forever.
Are you running a PCV with that AOS?
If so - a stuck PCV may cause similar behavior....find out the cause, before applying fixes.
