1 - 8 of 8 Posts
G
Whats a good price for 04 sti takeoffs with 4k on them?
Also does anyone know how much it will cost to install these?
Thanks
Take-offs of what? :confused: Struts? Springs?
2008 SG Model D
Yeah, for some reason that is what people around here have been associating take offs = struts and springs...but in actuality take offs are just parts that were taken off the car :lol:
As for the price it will range from about ~$400-$800 depending on the condition of them and if the seller is feeling generous.
Do you know if any of them are clunking?
Frank & the FXT
install?.....do it yourself man, requires few tools 12mm, 2 x 19mm, torque wrench and maybe a breaker bar. If you have the whole assembly it's easy, the whole strut only has 5 bolts holding it on (brake lines dont count).
Then just go get an alignment done afterward.
G
yea i mean spring and strut take offs.
No clunking that he knows of. They are local so if I get them I will be able to take a look before I purchase.
they have 4k miles on them so they should be in decent condition. $500 dosent seem outragous for them i guess.
05 XTi FMIC
FYI: Stealthback + STi takeoffs can = scraping of exhaust bits.
Good luck
2004 FXTi
$500 is a good buy for that low of mileage. It really is a pretty simple install job, especially if they already have the tophats on them.
Regards,
Justin Wade
2004 FXTi
worn out cams
05 FXT
I just picked up some "takeoffs" with 40,XXX miles on the fronts and 1K miles on the rears for $350. 5 bills sounds pretty good, as long as you are convinced there is 4K on the STI set.
1 - 8 of 8 Posts
