1 - 7 of 7 Posts
admin
Which one? The boost gauge from Subaru or an aftermarket one?
The Sub kit guy
2005 Forester X & XT VF39
Depends on your skills and where you are mounting it. The wiring and routing the of stuff thru the firewall takes about an hour. If your mounting it on the steering column (like stock), that alone will take another hour. You have to take a bunch of stuff apart and lower the entire steering column.
60-90 minutes if dash mounting
90-120 minutes if you column mount.
anyone know?
The amount of time it takes will depend on what you're installing. I installed a mechanical gauge in my '07, which required a hose to be run from the engine to the gauge. :smile:
You can view my boost gauge installation here. The hose routing into the cabin can be viewed here. :wink:
1 - 7 of 7 Posts
