2001 Forester L.
Replacing front and rear bearings.
Read Subaru bearing replacement bulletin. It gives the distance from the hub to the knuckle in terms of a special tool. I am using a hydraulic shop press, so their measurements do not apply. Does anyone know how far to press the hub into the knuckle, after the bearing has been installed in the knuckle?
Thank you.
Thank you.
