I have removed and replaced the TPS and the idle air control solenoid. The IAC had to be cleaned as it was well sooted up but they are both back in now and I have found how to set the TPS, which is done, but I would like to adjust the idle speed as it'a bit high (750-800rpm). I read on the scooby forum how to do this using the screw on the idle air assist solenoid but I can't find the IAA. Does anyone know if that is the correct proceedure and if so, where the IAA solenoid is please.
