As you can probably see, I haven't mastered Thumbnails & rotating the picture bit yet.
Any tips??
Regards
AM
- Open your Photobucket album, which contains the photos you want to rotate.
- Click "Edit", which should be above the photo you want to rotate.
- Near the top will be the rotate arrow. Click until it is right side up.
- Click "Replace Original"
By "replacing your original", all the links that you have set up will now point to the corrected image. If you made a "copy of the image" then you would have to go back to your post and link to the new image.
Be aware!!! When you check back to the post after you have edited your photo, the old un-rotated photo may still be "
cached" (saved) in your internet browser, and you might have to "
refresh" the page a couple times before the new image is loaded (for you and anyone who has already looked at the tilted photos; new visitors will see the new photo right away). Press the
Refresh button on the tool bar. If that doesn't work try to press CTRL+F5, which will force your internet browser to re-download all the images.
I hope that helps.
