2019 Subaru Forester
My wife loves her new Forester but hates the horn.
After doing a quick Google search I see that there are several different options. Single horns, double horns, low tone, high tone.
I'm looking for something easy to install and sounds better than the OEM one.
Any suggestions?
Sent from my Nokia 7.1 using Tapatalk
Seems like the horn of choice on this forum is Hella but not sure how easy they are to install. At the minimum you are probably going to have to remove the grill with any horn replacement.
Yeah, I get that part. But I saw a couple of horns that requires a new harness. I'm looking for a good horn that's plug and play.
Is the Hella plug and play?
2004 Forester XS 5MT
I went with the Supertones, I made the harness its easy with a few bucks worth of parts and a few minutes of soldering to make it neat and tidy, but its also likely someone sells a harness. I also bought the Grimmspeed bracket but you can make one out of light steel bar or equivalent.
