1 - 20 of 337 Posts
1999 Forester S 5spd MT
Hogan's swapped 1999 forester
Part 2
Update 28 August 2017
This is part 2 of this build. The first part can be viewed below under "Original Post" and runs from December 2012 to August 2015. I will no longer edit that section.
Part 2 begins on Page 22 10 August 2017 to current after I had left the car in storage for 3 years when the swap failed to start.
16 November, 2017
29 September, 2017
After splitting time between Alberta Canada for school, and summers at my parents house in the Netherlands for 3 years, I have returned to visit my brother in Detroit and work on the car again. When I left the car, the fuel pump would not prime when the car was switched to ON. In an effort to get it to start, we manually wired a fuel pump switch to build pressure. The car would crank and nothing would happen. We also attempted to read the map on the ecu with a tactrix cable and ecuflash, but would receive error messages when trying to connect. While the car was in storage it stopped cranking altogether, and the power would die as soon as you tried to crank it. The battery was also left in the car for a winter and was down to 4 volts.
The first thing I did was remove the entire engine harness to do a visual inspection. We also removed the cooling and intake systems except for the intake manifold. After finding nothing obvious with the harness, I put the same battery back in (it was run through a reconditioning charger and was brought back to 12 volts). Instantly the car cranked again, to much surprise, as only months before the car would just die. We then began plugging in the harness connector by connector, and it kept cranking. With the engine harness now fully reinstalled and grounded, we tested for spark, and the plugs were arcing to the block. Spark, check! Unplugging the CPS sensor cut the spark, so the ecu was functioning properly.
I then began fixing the fuel pump priming issue. With the help of consulting friends via facebook group chats, we traced the wiring back to the fuel pump controller, where we found that the wires to the pump had 12 volts during ON ignition. The harness merge done by iWire included a new fuel pump ground wire to the pump connector, so we traced the power wire back to the pump, and installed new connectors under the rear seat and back to the pump, and what do you know, the pump primed at the first turn of the key. We then inspected the fuel plumbing to make sure it was all correct, and we had flow through the damper, through the rails, to the pressure regulator, and back to the return line. Fuel pressure, check! Many times i would crank the car for 10 or so seconds attempting to start, and then pull a spark plug out to check for fuel in the cylinders, but there never was any. We also performed cranking voltage, and resistance checks on the injectors, and all looked good, but the car still would not start.
We then pumped all the old gas out, and added fresh gas. That night it was the same problem, crank it over, no start, no fuel in the cylinders. Feeling defeated and thinking we needed to pull the injectors to bench test them, we went in to watch TV. Late that same night I returned to the garage, and heard a large pop during cranking. So I let it sit for a few minutes, turned on my camera, and around 1am while everyone was asleep, it started for the first time. Car starts, check!
I don't know what caused or prevented it from starting, maybe it was the fuel and I had just primed the system enough to get the new stuff into the rails. Maybe it was an engine ground, and taking it out and putting it back in again was enough. Maybe it was the CPS sensor wiring, as days later I noticed that the heat shrink on the wiring has fossilised and actually pierced through the insulation and the wires, and the connector was barely hanging on. It may have been just having the car in a nice, spacious garage, with the proper time to really look at everything, and troubleshoot then fix issues one by one. 3 years ago was a mad scramble to actually get the car running before I had to leave, and it lead to us cutting corners, which is why we screwed up the fuel pump wiring. All that matters is that it runs now, and I am happy.
Since getting it running, we had a bit of a list of parts to order to get the car to a driveable state, including a new tactrix openport, because we lost the old one. Yesterday I was able to connect to the ECU on the first try, and downloaded the map on the ecu just fine, so that still confuses me. It was a stock 02 wrx map on the ecu, so now we can scale up the injector flows and get ready for tuning. I also ordered new pins, and rewired the CPS. We got a new front O2 sensor, and a new radiator that actually fits, as well as a new SPT intake. The only thing stopping the car from driving right now is a rear brake line leak around the gas tank. Its been a rough 3 years, but we have made massive progress on the car in the last 2 weeks, and its been really fun.
Hogan
Day X - 31 August 2017
Current parts list on the swap:
-OEM 09 STi headers
-Greddy catless up pipe
-Invidia 3" catless downpipe
-Turbo XS 3" midpipe
-OEM 09 STi 565cc injectors
-OEM STi vf39 turbo with blouch ss oil feed
-OEM 09 STi stock intercooler with 04 STi scoop
-SPT Intake with MAF
-Agency power 3" hard inlet
-OEM 04 wrx EJ205 longblock
-OEM 09 Sti 11mm oil pump
-OEM 09 Sti oil pan
-OEM 09 Sti oil pickup
-OEM 08 Sti fuel pump (175lph)
-OEM 04 Sti brake booster/master cylinder
-OEM 04 Sti 5x100 hubs
-OEM 04 Sti Front lower control arms
-OEM 04 STi front and rear subframe
-OEM 04 STi steering rack 15.2:1 ratio vs stock 19.1:1 ratio
-Whiteline steering rack bushing
-Gates timing belt kit
-Stoptech front SS braided lines
-Grimspeed 8mm manifold spacers
-OEM 02 wrx pitchstop
-OEM 03 wrx ecu
-OEM 04 wrx driveshaft and tranny crossmember
-Megan street series coilovers
-04 FXT full aluminum radiator (ebay brand) with FXT brackets
-ACT Street Performance clutch
____________________________________________________________________________________
Original Post
Hey Guys, so I'm 17 and I bought my 1999 Forester S, 5MT on Saturday December 22nd 2012, for $3000, my first car. I'm stoked I got a Subaru! I have always loved subies and after my buddy picked up a fozzy about a year ago I thought, why not? So far I love her and awd has been awesome in the snow! This journal is mainly for me to track my progress but follow if you like!
Bought the car with 211, 730 km on it in Toronto, Ontario. Drove it back home to Ottawa (about 500km)
Quick notes
22 December, 2012 - bought the car, first car, as a 17 year old. Then started to make it cool.
7 November, 2013 - stock EJ253 blew so I began past goals to STI swap it, and I am using an EJ205 with STI bolt ons
14 August, 2014 - The swap was completed, however the car failed to start. The fuel pump wouldn't prime, and we couldn't connect to the ECU. I moved away for school and left the car in storage in Ottawa.
2 June, 2015 - Went to Ottawa and trailered the car to Detroit to store at my brothers house as when I was spending my winters at school in Canada and my summers in the Netherlands.
18 August, 2017 - It started I returned from europe to visit my brother, and got to work on the car for the first time in 3 years, and managed to start it.
to view the build follow these links in order
http://www.subaruforester.org/vbulletin/f115/hogans-1999-forester-125566/index21.html#post3874594
http://www.subaruforester.org/vbulletin/f115/hogans-1999-forester-125566/index21.html#post3874618
http://www.subaruforester.org/vbulletin/f115/hogans-1999-forester-125566/index21.html#post3874658
Day 1 - Picture of her getting gassed up minutes after I bought it
Summer 2013
August 2013
September, 2013
August, 2014
THE BAD (when purchased)
- She's a bit rusty (fixed June 22, 2013)
- There's a hole in the drivers side headlight, covered with tape (fixed! January 13, 2013)
- Drivers side fog light is pretty loose and was dangling out (Finished! New fogs/all brackets April 9, 2013.. Stupid sheared bolts :p)
- Overhead clock doesn't work :p (Swapped for scangauge II April 1, 2013)
- Missing a center cap in the front passenger side wheel (Replaced!)
- Rear wiper fluid pump isn't working (fixed! May 7, 2013)
- Cruise control isn't working (removed)
- A/C not working (removed)
MODS
- Acquire a rear cargo mat (Done! January 9, 2013)
- Change out the stock head and speakers (Done! Speakers changed January 12, 2013, head February 19, 2013)
- Colour match my front grille (Done! February 2, 2013)
- Full wrx cat-back (Done! March 4, 2013)
- UEL headers (Done! March 5, 2013)
- Interior Led's under dash (green to match dome/map/trunk lights (Done! March 7, 2013)
- Paint the rear letters because they are bubbling (Done! Painted white April 1, 2013)
- Overhead clock swap with scan guage (Done! April 1, 2013)
- Replace fog lights, because of rusted brackets (Done! FINISHED April 9, 2013)
- Paint wheels white (Done! April 8, 2013)
- Plasti dip two tone (Done! April 6, 2013)
- 06/07 17" wrx wheels (Done! Paired with Continental Extreme Contact DW 225/50 17 May 3, 2013)
- DIY mesh grill (Done! May 10, 2013)
- Tailight tint (Done! June 10, 2013)
- 02 WRX suspension, kyb agx struts (Done! June 10, 2013)
- Plasti Dip the whole car, Gloss black (Done! July 2, 2013)
- Cobb rear shifter bushing (Done! July 19, 2013)
- 02 wrx short shifter linkage (Done! July 19, 2013)
- NGK/NTK O2 sensor {Done! July 19, 2013)
- Rear cat delete (Done July 20, 2013)
- Hella 500ff's behind grill mounted (Done!)
- Custom Rhino Liner mudflaps (Done!)
- Straight pipe axle back (Done!)
- DIY Roof basket (Done!)
- Red out tailights
- Stripped interior coated in truck bed liner
JOURNEYS
- December 22, 2012. - First road trip, 500km home from Toronto to Ottawa. Great way to get use to the car.
- March 9-16, 2013. - Ottawa to DC and back, 2379km. Visited my old home, car performed great.
- March 31, 2013. - Ottawa to Kingston and back, 400km. Great day trip to visit my brother and his girlfriend.
- April 14, 2013. - Ottawa to Tremblant and back, 330km. Went to pick up my favourite 07 wrx rims! Great buy.
- August 8-18, 2013 - Ottawa to 1700km round trip, Visited my brother and enjoyed Woodward Dream Cruise!.
- September 14, 2013 - Ottawa to Lachute, Quebec. 260 km round trip, Went for Lachute Subie Festival! Convoy with over 80 subarus!
Hogan
Discussion Starter #2 (Edited)
Wheel well rust
Door handle
Fog light, when it started falling out
She also leaked some coolant when I started here up yesterday morning, nothing bad just a couple drips. Was only about -8C but was -18C overnight. Also woke up to this:
Today I managed to go to the dealership and bought some coolant and filled my reservoir, also stiched up the fog light, and after a not so friendly collision with a snowplow bank I got a lot of snow up in the plastic guard under the engine. Turns out 2 screws were missing and the snow cause it to hang down to the side, so we took it off, cleaned it out and put some new screws in! Also this afternoon on my way back from the dealership the overhead clock came on!! But on my drive home tonight I noticed it didn't come on when the car started.
Up in the air for the first time, putting new screws in!
Patch job on the fog light
03 XS 5MT
Nice start, there's a thread about the clock not working. It's a wire that needs to be sodered, but if you don't have experience doing that you can replace it. Are the brackets on the back of the fog light broken? There should be two with two screws, those should be easy to source so you can get rid of the zip tie.
Yes I've heard about the wire and the clock and will get around to soldering it but its not a necessity right now since the radio clock works fine, and the bracket is basically missing, only pieces are remaining. Thanks!
Re-soldered my clock together today and it still doesn't work, was wondering if there is a replacement thermometer or something someone has managed to put up there. Also slapped on a big sticker of a friends company on my rear window and ordered some goodies that I'm really excited about!
Sent from my iPhone using AutoGuide.com Free App
2014 Impreza WRX 5 speed manual
Hey. It seems like you're off to a great start. I have a '98 Forester and had some tips for you concerning the rust on the rear wheel wells. My Foz is doing the exact same thing. While working on another project I completely gutted the hatch area down to the metal. There was rust everywhere, especially on the strut towers. It might be worth looking into. Also, feel up in the wheel well (between the rusty area and the tire). Chances are you'll find the metal loose. Mine was so bad that a chunk just fell off in my hand! Water from the tires gets in from behind the rear quarter panels and just sits against that lip. Best of luck!
John / LIP89
Discussion Starter #10
John / LIP89
Thanks, I'm gonna be working on the rust with Afterbang in the spring when its bearable to work on outside. Thanks for the tips!
Nice pickup there!
Enjoying it in the snow?
Thanks! And yes!! So much fun to play around with in parking lots and when we get about a foot of snow on the roads she just plows through it past all the stuck civics :icon_biggrin: Although this past week hasnt been good, little warmer temps and a bit of drizzle but the roads will be covered again soon enough!
Will also post an update once I get all my supplies in! :)
Discussion Starter #11
So I ordered new speakers! Sony xplod's, 6 3/4", I just did the front ones we'll see if I do the backs. Huge improvement over the stock ones (and my right speaker was blown too.) Also bought a couple green led's for my interior. Biggest thing was that I visited a guy parting out a 98 forester. Bought the headlights and rear cargo mat off him for $40, and he threw in the corner lights and fog light brackets I spotted for free! So now I'll be experimenting with a reflector delete on my second set of corners!
New Problem
My keyless entry system has stopped working, tried 2 remotes, both with brand new batteries and to top it off, while the key is in the "start" position, so while I'm driving, the door open light will flash on and all my doors will lock/unlock. I can't help but think these issues are related. Anyways theres a jumble of cables hanging down to the left of the clutch pedal (off the dash board) Is this where the keyless entry module stored? Still I have the least of a clue of whats wrong with it.
Hogan
Discussion Starter #12 (Edited)
So i tried to swap in the fog light brackets today, and it just so happens I didn't do a thorough enough investigation. I bought the wrong brackets, although the ones I bought are in much better shape than the original ones so I will swap them on. Turns out what I need is the piece that screws on to the back of the fog. I'm not sure if it comes with the fog light but I guess the search is on to find another person parting their foz. I did swap in my new headlight but the damage is missing fog light and I snapped the 2 bottom grill clips off -_- Also unplugged the keyless entry module, I guess I'll have to suffer with the key lock for now. :(
ImageUploadedByAG Free1358126917.610499.jpg ImageUploadedByAG Free1358127038.133561.jpg
Discussion Starter #13
:woohoo: update!
About 2 weeks ago I bought some ikea cutting boards to do the DIY mudflaps, also began colour matching my grill! Sanding, priming, painting then clear coating took about a week because of the difficulties of spray painting in -30 :p Then I let it sit for about a week to avoid the freezing rain. Went out yesterday and got the hardware for the mudflaps and did them in my garage. Turns out I can get the car jacked up and take a wheel off with it inside. (Still cold in there though, haha) So today I went out and shot my car after work, nice overcast day with a bit of snow!
car looked funny with no grill or fog lights
Sanded
Primed
Ready for install
Rear installed
The rear ones are gonna stay red until I get sick of them, might play with the shape of them a bit, but probably not until the spring. I'm super stoked at how the grill came out. And I also ordered my new radio! Got a JVC KWR900BT, I wanted a double din that could shine green to match my interior and with a big volume knob. So I went with this over some entry level touch screen ones, the screens on those aren't very sensitive so I stuck with buttons!
Good side shot full body shot showing the flaps and the grill
This plow really shows how small our cars are haha
So she doesn't look bone stock anymore, and of coarse I drifted up the parking lot after :) Next mod will probably be something to do with the tailights, but we'll see if that happens before winters over
Discussion Starter #15
nice! flaps turned out good!
Thanks buddy. Currently have jackie at annapolis subaru trying to find me some fog light brackets. My other option is to hit the pull and pay buy its too cold to pull stuff outside for my liking. Might be running fogless until the spring.
1997 forester manual
Nice car but i don't like the red mud flaps ! Well, i also have a few dents on mine but i remember an older guy told me once : "une voiture, ce n'est pas une tire lire !"....so i stopped repairing my dents !
1 - 20 of 337 Posts
