1 - 20 of 31 Posts
B
Guest
Any opinions on trailer hitches for the Forester? Subaru hitch vs. other brands? I would be using it 99% to hold a hitch-mounted bike rack, but could conceiveably tow a small trailer with it. Do they (all) bolt right up without additional holes being drilled? I'd like to install this myself. Thanks.
#8 Post ho
1999 Subaru Forester
I have a curt
It was not very easy to install
Had to make some modifications ie cut some pieces out of the hitch so it could bolt on
Beefy as hell but I also had to buy a wireharness seperatly
B
Guest
SenorSubie said:
I have a curt
Wire harness issue doesn't bother me too much, but looking for something with little to no need of "alterations". ;-)
#8 Post ho
Yeah but it cost me another 50 bucks.. wiring was extremely easy, the connector is already tucked in the spare tire area, just plug in the adapter box, and run the conector throught the gromit near the spare tire
I'm going to purchase a stiffer exhaust hanger for the rear section that seems to make contact with the hitch under hard acc. or if a "large" person is sitting in the rear drivers side
2001 Forester S 5 MT
I have a Hidden Hitch on my 01 and use it mostly for a hitch mounted bike rack. Never a problem. I have used Hidden Hitches on my last 4 cars.
for the trailer wiring, I ran it behind the bumper and tucked it up behind the license plate from the top. When I need it , I pull it out. It completely hidden, protected, and easy to use. The description sounds funny but I can take a pic if it helps. I wiring harness is a direct plug-and-play but I did have to cut it to get the wiring through a grommet in the spare tire well to the outside.
2006 Forester
I just put on a Drawtite and it mounted up with no hassle. Drawtite and Hidden Hitch designs are very similar- identical for most vehicles. The finish is different. The Hidden Hitch has a matte black rough finish while the DT has a smooth, glossy, finish. I have owned both and both are very solid and fit extremely well. I prefer the Drawtite finish and it is easier to keep clean- if you ever clean under the car.
Drawtire and Reece and made by the same company. Hidden Hitch is a separate company but I hear it is owned by Drawtite's parent company. You can't go wrong with either one- for me, it came down to the finish. I prefer the glossy powdercoat.
B
Guest
Discussion Starter #11
Thanks for the input all....
I was wondering about the Hidden Hitch, I'd seen them on ebay at a decent price. Glossy finish might be nice though....:think:
I'm happy with the Hidden Hitch. I hadn't really noticed the finish, because I can'r really see it. But I don't won't anything glossy down there anyway.
2006 Forester
I've had both and while the HH finish is very resistant to salt spray as they say, it seems to not be a durable as the Drawtite's powder coat glossy finish. My HH had some rust spots where thigs had either hit it or rubbed against it while my Drawtite one never did so I personally went for the Drawtite again. However, the HH rust never got out of control and didn't affect it in any way.
B
Guest
Discussion Starter #14
Decided to go with the Hidden Hitch from Senor Subie's neighbor :shock:
The install looks like something I can handle, as long as the rusty nuts & bolts come off like they're supposed to :roll:
#8 Post ho
Alright if you have any problems, just let me know :lol:
2006 Forester
Yeah, don't forget to take off all the brackets and stuff or you will wonder why the bolts are not longer.:grin:
#8 Post ho
remember they use WELD nuts.. so.. yeah.. i didnt' know.. and.. I'm not going there :tempertantrum
B
Guest
Discussion Starter #18
I guess the WELD nuts require the BIG PERSUADER bar? :spinnasmiley
#8 Post ho
Ouch.. 37~ is alot of money for just a simple install..
They should come off pretty easy, but I tried to.. loosen the weld nut instead of the bolt :tempertantrum
I ended up taking a recipricating saw and cutting off the little bugger
1 - 20 of 31 Posts
