I was reading an article and the author was recommending against using LW Shockproof. He claims that the small particles in suspension will eventually cause a buildup of material on the inside of the case, and may block/clog small oil passages.
What say you?
I have been using the stuff and yeah, you can now downshift into 1st at 25 mph without issues.
I find it also helps if you *slightly* overfill.
LOL that reminds me. GM mounted the T5 in my Camaro cocked at an angle in order to increase the amount of oil that it holds. Essentially raising the fill hole by rotating the tranny. Seems they thought it should have more lube oil (overfill condition) than Borg Warner designed. Thing uses ATF. Problem with that, it also raises the drain hole, so you have to use one of those little hand oil pumps to suck out the last bit of old oil.
What say you?
