Hi, I've just purchased a '98 Forester non turbo and it hesitates on acceleration, hot or cold. Also fuel consumption seem high but there is no apparent smoking on acceleration.
Have changed the plugs, leads, fuel, oil and air filter. Just done the cambelt and changed everything there.
Knock sensor seems to be fine on the multimeter, timing advances ok when reving when checked with timing light.
Have cleaned out the throttle body and checked every connector I could lay my hands on.
The CEL is not coming up on the dash and my OBD2 reader won't connect but it did momentarily flash that there were no codes.
Any ideas where to go from next? - I will check the fuel pressure next, what should it be? and what volume for a 2.0l motor?
Cheers.
Cheers.
