2010 Forester
Hello, everyone. Just received my COWON AW1 dash camera along with COWON uninterruptible power cable (UP2). Need you guys to help me to figure which is the best way to connect it for my 2010 subaru forester N/A. Any help will be kindly appreciated :Banane35:
2010 Forester2.5XPremMT
I use the reserved power for fancy center mirror. It powers on when key in accessory mode. In other word, perfect for a dash cam. IIRC, All you need to do is to remove the front map light completely and you will find a connector not bring used. Use a meter to find the right ping. there is enough room to hide a 12v->5v adapter there.
Cheers.
2011 2.5x Auto
Battery connection
Some dash cams also need a battery connection. If you do, the two map lights are tied together and go the battery.
Easy to remove overhead console. Two screws in the covered pocket, then pull down, to remove the two push-pins.
