Hi. I just took my Forester to the annual inspection and it was rejected because its was smoking a lot. The didn't even put the machine to test emissions because they say the smoke will harm it. (I seriously don't believe that). I told the guy to show me the smoke. I started the car and no smoke. He revved the car and no smoke. He asked me the favor to rev it so he can see and finally the smoke appeared. It was blue smoke in a moderate quantity. We left the car in idle and the smoke kept coming out and after a while it went out. I went out from the inspection site (very unhappy) with an order to correct the problem within 15 days. The I noticed that sometimes when I revved hard the car, the same smoke came out, but not always. Sometimes I can rev hard and go into boost and no smoke is seen.
I'm having a hard time figuring out the source of the blue smoke because:
- A year ago, I serviced the cylinder heads. All the seals were changed.
(I don't want to think that within a year and 6000 miles the valve seals will fail)
- The piston rings and ringlands were ok. At least by visual inspection. My engine has 66000 miles.
- A month ago I repaired the turbo. They changed the seals off course.
Where else should I look??? I've read that the PCV valve might cause blue smoke which would make me happy as a cause considering the low cost, but I'm also having nightmares thinking of the need to repair the whole engine as the PCV would be something too easy and lucky to get rid of oil smoke.
My logic is that if a ringland is broken or if the piston rings aren't sealing properly, the blue smoke should be there all the time right? Or I'm absolutely wrong? I don't know why the smoke is intermittent.
Thank you for your insights.
