1 - 1 of 1 Posts
2007 Forester X
Hello.
2007 Forester here, bad wheel bearing. I have removed the knuckle from the vehicle. The hub and bearing are still attached to the knuckle. I have access to a hydraulic press and wanted to confirm the right way to get the hub out.
Do I lay the knuckle outside-side down, remove the inner seals, press out the hub from the inside of the knuckle, then flip the assembly, remove the outer seal and snap ring, and press out the bearing from the outside of the knuckle? That's what the drawings seem to show.
Thanks in advance.
1 - 1 of 1 Posts
