what one would u say best to for a uk or Japanese spec one?JDM will usualy have a small square numberplate as opposed to the oblong english ones. Also the rear fog light will be a caravan light badly attached to the bumper. The UK ones have it built in to the bumper itself. Keep and eye out for multifit alloys wrapped Linglong drift tyres of death. JDM will probably have an interior designed by Frank Zappa on a comedown, the UK interiors were simply designed by a blind man. And the last thing you should look for is when going to view the vehicle the owner will say JDMYO! a lot... probably.
hmm sounds of that think im gonna look for a Japanese one my insurents wont be that much as i just had a nissan pulsar gtir at 320 bhp was looking at the pictures of them the jdm do look much coolerThe JDM has a TD04 turbo as opposed to a TD03 on uk, And a few other minor engine differences I think. A standard JDM is about 220 BHP (up to around 250 BHP if run on a quality high octane fuel.) compared to UK at around 177BHP. So insurance is going to be higher. As Brian said service history is important. I think the JDM Foresters look better than the UK model, but am not sure if thats just because they are different. You will prob be best off with a UK model.
hmm 400 bhpIf insurance and maintenance aint gonna be a prob then go for a high spec JDM one. The STI and XT models have the 2.5 engine, good for 400 BHP easy.
The Japanese spec stb model has more bhp than a uk s turbo so if you want more power as standard go for the stb ....if you really are unsure about what to look for, why don't you ask the current owner if you can take it to a reputable garage or for an mot ...if there is nothing to hide then they should not object to this :biggrin:
if it were me i would be looking at these main things
1.worn tyres
2.worn brakes
3.condition of whole exhaust eg up-pipe is prone to splitting with age and can make the engine sound noisey on tick over.
4.blue smoke on cold start
5.knocking engine especially at around 4,000 rpm
6.check for oil leaks around cam cover gaskets , very common
7.check clutch and smooth operation of the gearbox
8.check oil and look for cream on the filler cap
9.check history if it has any .....especially to see if the cambelt has been replaced
10.check time of next mot and tax
hope this helps !
nar lol it still helps knowing there common problems and faults what to look out for i think in year or so are get flat four engine rebuild it with write up mabe lolha ha ! i've just noticed that you said you are a mechanic so my last post doesn't really apply as it sounds like i'm telling you how to suck eggs:biggrin: ......hopefully it will be of use to somebody later on maybe :biggrin:
thanks be other thing 2 remmberIf you want a manual then look for the S/tb (some are auto though) . The T/tb is auto only.
Interior trim is slightly "better" on the T/tb but this depends upon the strength of the rose tinted glasses !!!!
Cheers
Brian
Seat arm rests and wood trim were a factory option on all models of Foresters, even some UK S-Turbo's have then and some don't.T/tb comes with arm rests on the seats and a fake wood trim.!
If you can go for a top spec freshly imported SF5 S/Tb. Far more options and power than the UK cars. Most Impreza bits fit although you cannot remap the pre-2000 Auto's.
First job must be to fit a classic Impreza STi rear anti-roll bar, cost around £20 s/h and best mod for the money, tightens up handling until you can sort out the wallowy ride.
Watch plastic radiator end caps for splitting, S-Turbo radiator does not fit JDM car without major modifications.
Service history is difficult to prove on the imports and even then you cannot read most of the Japanese in the service book.
Best advice - Just get out and buy one - They are fantastic.
jdm ones the imported ones right? still a n00b to this lol
any import one would be a jdm or this me being a twat
thanks for that are be able to get a rad from internet if i got jdm one
hardest thing is going to be buying jdm i been looking around seen like 2 so far
