Hello
I finally bit the bullet and have spent the weekend changing my broken transmission over, but having finally got the new one in, it makes a bad noise going forwards in all gears and is fine in reverse.
My car is a 1999 non turbo 2 litre forester and I put a 1998 transmission in- should this be ok??
Original - has 4 bolt holes top and 4 on bottom
replacement- has 2 top (starter has a stud for bottom fixing) and 2 bottom
really would apreciate your help as I am stuck with no car at the moment. Not sure if box is broken, final drive ratio is wrong.
thanks again
Tim
thanks again
Tim
