Hi Everyone – I need some help figuring out my engine build. I’m looking to be in the 450-500 WHP range, but I’ve been out of the scene for so long that I don’t know what the parts and pieces are anymore. Let me give some background on the car first. (You can find the whole build thread here: https://www.subaruforester.org/vbulletin/f115/ultimate-daily-driver-project-99894/ ) but the short and sweet of it is the suspension is basically where I want it, and so now that I have pulled the car out of a 5-year storage, I’m ready to start on the engine. While the car was in storage it overheated badly. (As was reported to me by the person storing it for me.) I didn’t get to see, but when I pulled it out of storage, there was no sign of oil in the coolant (or any coolant for that matter) no sign of coolant In the oil, and no leaks under the car. So I’m not sure if the heads warped or not. If the heads did warp, I may just buy a staged block from IAG or someone similar, instead of dealing with getting the block and the heads machined. Either way, I’m looking for help on what I need to hit those numbers, and what the best companies are. Granted everyone will have different opinions, but usually, the best brands will stand out. So I’m going to make a list of the parts I’m already planning, and let me know if there are better products out there, what I’m missing, or if any of the parts I have planned don't play nice together. TIA (if this kind of stuff isn’t allowed anymore, feel free to delete.)
• Intake – Unknown
• Cosworth Forged pistons
• Fluidampr
• I wanted to go 18GXT-R, but I’m not sure if it will hit the numbers I want so maybe 3.0XT-R
• IAG Performance Competition series AOS
• IAG or Radium auto Top Feed Fuel Rail
• Radium Auto Fuel pump hanger
• Custom front mount intercooler from bellintercoolers
• KoyoRad aluminum radiator
• Subaru 68 degree racing thermostat
• Bline motorsports top mount oil cooler
• Killer B oil pan, pickup, & baffle
• Grimmspeed limited DP with thermal coating
• Grimmspeed exhaust manifold crossover with thermal coating
• Grimmspeed up pipe with thermal coating
• Injectors - unknown
• AMR Cast Turbo Inlet Tube
• AMR Un-Equal length header
• Cosworth air pump & tgv delete
• Prodrive 3-port boost control
• Omnipower 7 bar map sensor
• Fuel pump - Unknown
• Intake – Unknown
• Fluidampr
