flstffxe has posted the same thread I was going to submit, easily found with the Search feature.
As the others suggest adding some vehicle info to your Signature would help us help you, a location could be added at the same time and for the same reasons. Just use the pull-down menu in Active Links and Edit Signature, add vehicle info like year/model/transmission, you could also Edit Profile at the same time, then you're good to go.
Luckily you have only a few posts and mentioned in one of them that you had an 08 X. Otherwise I wouldn't have gone looking for an answer and likely passed on the thread or made a similar request for info, which takes longer for a response.
Good luck with the install and tell us or post how you did the install.
