HELP: Headlamp socket repair & Recmmendations for headlight bulb swap
1013 Views 1 Reply 2 Participants Last post by  hrbutler52
Working on my wife's car before winter sets in:
Questions #1, headlamp socket.
The drivers side headlight keep burning out. The plug has heat damage so I THINK the answer is replacing that electrical wire. I saw replacement headlamp sockets on Rockauto with a ceramic plug but I cannot see where to switch the wire at or if I just splice them? Is there a better solution?
Question #2, Options and Pros/Cons of swapping standard headlights for something better.
My wife needs better lighting for night driving. I don't understand the differences between HIS, LED, and all of the other options. Also, would changing lights also entail changing the wiring too?
I look forward to hearing from the community. Thanks!
Derek
1 - 2 of 2 Posts
Question 1 As the existing connector is heat damaged, it will have to be removed and a replacement spliced on. Try to find heat sealed butt splice connectors to prevent corrosion of the splice joint. As they are inexpensive you might consider changing the passenger side at the same time.
Question 2. If you want to use a different light source [HID, LED], the entire headlight assembly should be changed to properly control the light so as to not blind on-coming traffic and to get the max effect from the new light source.
Both HID and LED require controls that are not present in a vehicle that was equipped with halogen lights.
There are higher light output halogen bulbs in the standard wattage, that give better vision at the expense of shorter life. Higher wattage bulbs may cause damage to the wiring [hence the high temp sockets at Rock Auto] or to the plastic headlight structure.
Hope this helps.
1 - 2 of 2 Posts
