2007 XTEN
HI Guys,
Just been installing my gauge pack but have hit a snag! I need to tap into the vehicle harness to get to a speed signal. It should be on a 22 pin harness connector coloured green/black, problem is I cant find a 22 pin conector anywhere that matches! Anyone have any ideas? The car is a RHD yr2000 pre facelift turbo
Cheers,
Giles
MY11 WRX STi Sedan 6MT
Would be advantageous to know what you are fitting and a 22 pin connector seems rather vaque.
Usually you tap into the vehicle speed sensor output of the ECU.
If you go here..............
JollyGreenMonster.co.uk
and look at the pin outs and pin data for a MY99/00 the speed sensor output is pin 26 of connector B135 on the ECU
2007 XTEN
Thanks don,
The instructions for the pack i'm installing are here http://www.scoobymods.com/factory-gauge-pak-scans-factory-t151.html?t=151
It's a bit vague but it looks like I need to tap into a connector under the dash board, and the only one with a green/black I've found is actually for the right indictor :icon_confused:
Thanks for taking the time to reply I'll take a look at your link to see if I can work it out
Cheers,
Giles
Giles,
First off the, wiring between Impreza and Forester differs slightly, so what you are looking for may not be the same.
Having looked at these instructions, what you are trying to do is tap into the speed sensor link at the instrument harness to bulkhead harness connector rather than having to run a wire to the ECU.
As an example the following shows the wiring for the MY01 Forester.....
The connector they use would be the i2/B37 connector.
In this instance it is 32pin connector (not 22pin) and the speed sensor wire is Green/Black and is pin7 at this connector.
Following the wire back to the ECU it is pin A1 i.e. Pin 1 on plug B134
Check out the ECU plugs and pinouts on Jolly green monster site and find which layout yours is. You should then be able to link in at the ECU.
