1 - 1 of 1 Posts
05 FXT, LGT
All,
A little background first. I did a 6 speed swap into my '05 XT and that included the spacer delete. This brought the intercooler and hood closer together meaning I can't use my stock intercooler splitter without cutting it up (I may still do that). So I purchased a splitter from an 02-03 WRX to install. The bolts all line up, there's just two tabs that I need to bend out of the way. The problem is that the splitter doesn't fit in the scoop. It's too tall. I dug around here a bunch to figure out what splitter I needed and this seemed to be correct.
It seems that the 05 XT and the 03 WRX had the same hood scoop. Am I missing something? Are the scoops on those two cars not the same?
Thanks,
Kris
1 - 1 of 1 Posts
