2004 Forester XT
Hi all,
I changed the driver's side spark plugs today and I started to head down the road. My check engine light and CC are flashing and I have no real boost to speak of. Could this be a poor spark plug installation on my part or something larger?
1998 Forester
If it ran good before the spark plug change it probably has something to do with it. Check to see if the white coil harness connector is on the front coil.
1999 Forester S
what all did you remove on the drivers side of the engine? accidently knock off a vacuum line, disconnected something and forgot to put it back
2004 Forester XT
I'll go back and double check the plugs, but the coilpacks fit back on without any problems. As for what I removed it was just the battery and the wiper fluid reservoir. I'll have to check that too. I may have accidentally disconnected the air filter box when I jacked up the engine...
