1 - 2 of 2 Posts
2004 2.5 FXT manual
2004 forester xt
Ej255
I have had the intake manifold off a few times before but this time it sat for a while and i removed the leaky fuel lines under it. Usually when im bolting it back together the vacuum lines just kinda match up and i can tell where they go. This time i cant find a hose to line up. It comes out of the block and Tees. One side goes to the turbo inlet, other side?
The best I could tell from a diagram i found was that it goes to the center of the intake manifold. It might be that i have misplaced a hose, or a hose came off the manifold while i was removing the fuel lines.
I am replacing the fuel rails and lines with after market braided lines in order to eliminate a pesky fuel leak under the manifold. I will probably have more vacuum line questions as i the project continues.
Im sure this is an easy one for most of you so thanks in advance!
2017 Forester XT Touring
pretty sure you are right and that hose goes to the bib right under the throttle body. Usually that hose it part of the PCV when you purchase a new one, but any old fuel line should work.
1 - 2 of 2 Posts
