1 - 14 of 14 Posts
2003 XTi Cross Sports 4EAT :(
06 Forester
are the "stock wires" coming from the stock horn and alarm both positive? if so then a 3A Barrel Diode (Model: 276-1141) from radioshack would do since it will only serve as a trigger for your relay. cathode side to the 86 pin and anode side to the horn/alarm side. :smile:
maybe he means the beeper? man imagine unlocking your doors with these babies on.. OUCH :lol:
My 03' came with keyless entry but not a stock alarm, when I got the OEM alarm kit, it has you attach a third horn to the car by the strut tower. Hence why I was thinking to wire it like I have it in my diagram. I have no idea where the stock keyless entry piezo beeper is but would prefer that to stay as is.
06 Forester
the piezo beeper aka "beep / beep-beep" sounds are wired and activated separately. It is just an audible indicator for the door locks. The horn (strut mounted) are only activated when the alarm is triggered.
Discussion Starter · #10 ·
OK so my idea of wiring is the "right way to do it".
2009 Forester
Horn replacements are gravy
I just replaced the stock horns with some standard replacement horns for a domestic car, giving me a beefier horn sound and volume. I couldn't handle my wife laughing at my car every time I set my alarm, so the stock had to go. The replacement went super easy and took less than an hour for both. It was a little upsetting at how little of material is holding the front of my car together compared to my full size pick up I traded in for my Foz. Good luck
04 Forester 5MT
ahh. makes sense. good luck!
1 - 14 of 14 Posts
