1 - 12 of 12 Posts
2003 XS
Tow it to a garage and let it thaw. Then, drain the water and replace with 50/50 coolant/water mix. Don't start the car with a frozen water pump. It could throw off your timing belt and cause engine damage.
Mark
2008 Forester X Premium 5MT
Get it to a heated garage/shop and let it thaw. If it has block heater that can be plugged in also to help speed up the thawing. A block heater alone will not thaw out the engine however.
Agreed trying to start it would be a huge no no that could be costly.
1999 forester gls
Mark
cheers dude, only problem is i tryed to start it fired up on ,what sounded like two cylinders for about 5 seconds then stopped,then found out it was frozen...
The previous owner must be somewhat retarded to fill up only water as coolant if you live in a area where it get below zero degrees celcius.
Still try to get it heated and get it checked up before starting it again.
2003 XS
I hate to be a doomsayer, but that doesn't sound good, mate. It's possible that you broke your timing belt. I'd get it into a garage, thaw it out, pull the timing belt covers, and inspect the belt before turning it over again.
Mark
Mark
Even this is a better out come then the worst case scenario. A frozen cooling system can crack the engine block, heads, radiator, heater core....
As it thaws watch for leaks. :icon_sad::tissue:
07 fxt
thats what i was just gonna say.
broken timing belt would be the least of your worries.
i cracked a block on malibu when i was 15 lol. the freeze plugs didnt even blow it just straight up cracked teh block
1 - 12 of 12 Posts
