Headlight Low Beam Fail...2006 FXT
663 Views 1 Reply 2 Participants Last post by  simes777
Hi Guys, it's been a while since last post - hope all's well for everyone.
Yesterday, a strange fault has reared it's 'dark head'...the drivers side low beam and sidelight failed / passenger side working perfectly, and both high beams light up. Arrived home last night, swapped over the 15A fuses and LH+RH headlamp relay; the fault's still the same/relay & fuses all okay, similarly the driver side bulbs. Have searched the forum but can't find an obvious/common failure point.
Friday afternoon/in daylight I'll complete a thorough inspection of the wiring and earth ground contacts.
Apart from the above, is there a known/common fault the could cause this? Another not immediately common component in the front lighting circuits tucked away somewhere?
Maybe one of you have experienced this fault before?
Any/all help/advice greatly received.
Rgds
Andrew
1 - 2 of 2 Posts
It could be the ballast resistor in the headlight unit. It gets wet and then the light doesn't work - I believe you can dry it out, and it'll work again.
I'm not an expert by any stretch, but I had the same problem on my nearside headlight a couple of years ago.
Hope that helps... a bit?
1 - 2 of 2 Posts
