1 - 14 of 14 Posts
Yorkshireman, not a DUDE!
2011 Mitsi RA Sportback SST
Was out last night and realised that the headlights need adjusting downwards, probably because the car is sitting a little different on the new suspension. So, on a JDM SF 1998, can they be adjusted at home, diy job, or is it a garage and specialist equipment jobbie ?
If they can be done on the driveway.....how ?
Thanks
And yes, I realise that it is a electrical/lights question but as I drive on the left and the T/tb was not imported into the US, this seemed the best place to start asking.
Brian
MY11 WRX STi Sedan 6MT
Assuming all SF's are equal.....................
A garage door is very handy as long as there's enough room in front of it and the ground is level.
Cheers Don, I'll have a look tomorrow and see if I can spot the adjusting screw bits.
Brian
2002 SG XT Auto
Don't S/tb's have a turn switch on the dash just above the radio to do this?
That is for adjusting the headlight aim when you have a load in the back so you don't blind people.:biggrin:
That went right over my head :biggrin: but then again wouldn't want to get AP going on his pet hate :biggrin::biggrin:
2004 XT AT
Yes... and MoT testers turn it back to the default "0" position before doing the headlight alignment check. So it's no use trying to use it to set the alignment.
-- Steve
Discussion Starter · #9 ·
The JDM T/tb doesn't, hence the original question.
Brian
2002 SG XT Auto
Forgot it's a T/tb. Did you ever get the front corner marker thingy working?
Discussion Starter · #11 ·
Only manually ! Must be an electrical connection 'somewhere' ! Will have a look at some point.
Brian
1997 T/tb
is that the telescopic parking marker on the front left corner?
i have worked out that mine does not work if the temperature is less than 4 degree ?????
when its warm it works fine
strange!
Discussion Starter · #13 ·
strange!
Yes, that's the one. I just leave it pushed in all the time. When it is pulled up then there is a lurid green glow from the top so there must be power to it but no apparent motor to raise/lower. Never tried it in the cold !
Cheers
Brian
99 UK S-turbo
Not sure if the rules have changed recently, but MOT testers were not allowed to adjust the knob before testing.
Simon
1 - 14 of 14 Posts
