1 - 14 of 14 Posts
Mr. April 2008, Image Master
2005 X
I searched scooby mods and couldn't come up with a definitive answer. What is the correct torque spec for the header bolts? You know those six things hanging down from the block... ;)
P.S. Mods I wasn't sure where to put this since there is an exhaust thread in both N/A and the other kind of motor area... :lol:
22.4 ft lbs for the front, same for the rear section
13.0 ft lbs for the converter to centre pipe.
2005 X
Donkey chains...! :lol:
2005 X
Peaty says 28.9, Hondaslayer says 22.4...? I think I'll add them both, multiply by four, subtract Pi, divide by .5, and then what ever a quarter of the remaining is should be "balls on accurate." Right? ;)
You do have a 05 X correct?
I pulled it directly from the service manual.
2005 X
Hell ya!
The Modfather
Mine was from the 04 SM
2005 X
Discussion Starter · #11 ·
The 22.4 ft/lbs have it. Thanks guys for the info. Now I need to go out and take 7.6 ft/lbs of torque off the bolts. I put 30 on earlier. :(
2010 dodge caravan auto
did mine till they were tight :)
NahdaDamdyke said:
Torque 'em till they strip and then back off a half turn.
I see you and I are from the same school of thought.
Tighten down til it free spins then back it off 1/4 turn.
:lol:
1 - 14 of 14 Posts
