One to do on your tea-break.
Id like to more accurately know how many times, using the turkey baster method on the power steering reservoir, it would take to replenish the old fluid with maybe 80 or 90% new.
The guides say "do this a few times with a drive in between" or similar but I was after an answer that was derived using actual data rather than gut feel.
The following is an assumption for this game.
The total power steering system holds iro 650ml (?). Of that, 250ml (?) is held in the reservoir.
250 as a % of 650 comes out at approx 40% new fluid replaced but then mixed in with the old.
How do you then work out what another 40% change of new, to the now old/new fluid mix, would give you? I really hope this isn't something you learn at school and I've just forgotten how to work it out haha.
I realise its a game of diminishing returns with every change once you hit a certain volume because you're taking out a good chunk of the new fluid just to get a small amount of the old out. I also realise this isn't the best method. Again, I know it doesn't matter and I should just do it 3 or 4 times and be done with it. Not the point I'm trying to get at though. I'd like to know the maths for one, and satisfy my curiosity second. Only one guy in the office has worked it out so far but we dunno if it's correct. Be a nice ego boost for him if he's right :icon_wink:
By the way, my pump was making a horrendous noise from cold. Bought a new belt, but the one ECP supplied was 5mm too short and no amount of levering while turning pulley was gonna get that on. So I put the old on because it was visibly perfect and re-tightened. Performed the above method on the fluid and now its squeal free. Happy boy again
This is just for fun
