Status
Not open for further replies.
1 - 20 of 290 Posts
2011 Premium Manual
My son and his wife really like my Forester and are seriously considering a 2014 NA model. But I know them and they just won't remeber to check the oil regularly and won't add oil when necessary. So if they have an oil consumption prolblem like my 2011 has then their engine will eventually become oil starved and will seize.
I know that most 2011s don't have the issue. But some do and those unlucky onwers are screwed - Subaru will not help.
Does anyone know if the consumption issue been fixed on 2014s? I've heard some say that it was just a 2011 issue. I'm advising my son to stay away from the Forester, but if the issue is fixed then that changes everything.
Thanks
2012 Forester X 5 MT
To the best of my knowledge, the oil problem was rare in the '11s and was fixed by the '12 model year. Some folks may vigorously disagree with this.
I think the '14s have a low-oil-level light on the dash now.
Most Foresters seem to consume/evaporate around 1 qt. per 5K mile (plus or minus). So, a low-oil light is a good idea if the OCI is 7.5K and consumption is a bit on the high side.
2013 WRX Base 5-speed
Thanks
It seems to be hit or miss on the '11-'13 models. I'm willing to bet more then likely human error on some cases. My 2012 consumes around 1qt per 5000 miles. It now has about 40,000 miles on it and my current oil change is consuming a little less at this point. closer to 1qt per 6,000 miles.
2014 Forester CVT
you nailed it man... my 2014 forester ate 0.9 qt for almost 5k miles... i wasnt expecting it, but the oil level light on the dash came on and saved me... :)
so yeah now im checking it every other time a gas it up!
2017 Forester XT Touring Lineartronic CVT Si Drive
Thanks
From what I heard from my dealer, who is also a Subaru enthusiast, the problem with the rings was fixed on the 2014 models around Q3 of 2013.
:Banane35:
2014 Forester CVT
:Banane35:
Well if the problem with the rings was fixed, then there is something else wrong, or I got a lemon! :) But trust me I had to add almost 1qt when the dash light came on, and I only had 4900 miles since last oil change!
2014 Forester CVT
I have almost 2000 miles on my new limited in about a month. I have checked the oil three times, it has not dropped at all on the dip stick. I did drive it hard during brake in to seat the rings.
2019 Crosstrek 2018 XT
But trust me I had to add almost 1qt when the dash light came on, and I only had 49000 miles since last oil change!
1 quart every 49,000 miles is pretty good :icon_cool:
2014 Forester 2.0XT Auto
What do you define as hard? Did you break 4k RPM? did you just follow the owners manual break in? What did you do differently?
I'm just curious considering I'll be breaking mine in soon, and I'd like the best results leading to less oil consumption and to seat the rings properly :Banane29:
Forester of the Year 2014
SJ XT Premium CVT
Just did my the first oil and filter change this past weekend. 2760 miles on the odo. I followed break in procedures per the manual. There was no sign of lost oil.
2014 Forester 2.0XT CVT
I did moderate break-in, as in sometimes on highway would use paddles shifters and go to 5500rpm for a minute...no cruise either 1st 1K , cannot see any oil loss so far.
Subaru Drive : Insider - Three Facts About Engine Oil
Engines consume oil, whether that's considered to be a "problem" or not - it's a fact of life. Longer oil change intervals require checking the level in between oil changes and, if needed, topping off.
I am checking oil regularly with THIS Subaru, seeing all I read about it on here.
Funny my VW Jetta oil changes are scheduled for 10K miles ! and is all I did for 80K miles before trading in, no real oil loss either
2014 Forester 2.5i Prem CVT
My 14(built Q3 2013) has had zero measurable oil consumption after 4000 miles with the initial factory oil. I just did a change and will see if anything changes.
I am sure that we see many more posts when people have problems than when they don't. So I am not sure what percentage of the engines actually have this problem and even if they 'fix' it there will be some delay due to all the cars out there.
2015 SR5 Tacoma 6MT
Alright, so I'm thinking of a Forester with the 2.5i or XT. I know one of the technicians at a Subaru dealership and here is what he had to say when I asked him about 2.5 vs 2.0 turbo and CVT vs 6MT. He's a VERY good technician.
There have not been any problems with the 2.0 Turbo motor in the XT.
They have replaced a number of CVT transmissions under warranty-didn't mention what year or model vehicle and I didn't ask.
The oil consumption problem only seems to plauge the 2.5i with 6MT as the XT does not have this issue and they haven't had any complaints about consumption for the 2.5i with CVT. He told me that Subaru thinks it's the rings so they have been tearing down the motors and replacing the rings, none of the engines he's replaced the rings on have come back with oil consumption issues....Sooo it seems to be a ring problem.
How are these motors supposed to be broken in? Should they be driven in a normal manner and not babied until X amount of miles??
2011 2.5x Limited
There have not been any problem with the 2.0 Turbo motor in the XT.
2014 is the first model year for the Forester with the CVT.
2011 2.5x Limited
It's not limited to just the 6MT; it started with the 2.5 in the 2011 model year. Owners of both manual & auto trannys have reported it on the forums. My Limited uses about 3 qts between changes (7,500 miles).
2015 SR5 Tacoma 6MT
So this is normal?
How are these engines meant to be broken in?
1 - 20 of 290 Posts
Status
