1 - 2 of 2 Posts
2004 XT 5 MT
Greetings,
I wanted to know what tire pressure other Hakka IV owners are using on their forester. I was running the suggested 29 but recently bumped it up to 31psi. Anyone else have any input on this. I didn't notice any difference in the ride, I was thinking about going up to 33 or so, my whole reason for this is that it seemed like the tires were wearing more around the stud, not a huge amount but noticeable, anyone else have this happen?
Harbor Fright
2005 XT
You may want to increase your tire pressures. I don't currently have the Hakka4's, but the RSi's...and run these at ~35 front & 30 rear at 32F on the FXT- resulting in fairly even wear all around (for the way I gun it:) )...The wifs' CR-V has Hakka2's- which we run about 35 front & 32 rear at the same temp. Being predominantly FWD, the fronts take the brunt of the wear regardless of the pressures...
I have had studded 4's on two previous vehicles, but again ended up running in the same pressure range for best wear/comfort compromise.
1 - 2 of 2 Posts
