1 - 16 of 16 Posts
2005 Base 2.5x foz
Will they fit a 2005 forester front and rear with STI springs and WRX wagon struts? (assuming they came off an 04 + impreza)
Also what's the going rate on these used? I'm looking at a set for $300
Thanks!
Pleiads' biggest leghumper
04's 2 FXT's.
Yes they will fit.$300.00 is high for a used set.
joe r
2005 Base 2.5x foz
Seller says they're at 15k Still high?
I'm thinking maybe $300 shipped to me (cross country) would be fair
99 UK S-turbo
One word of caution for you.....
GroupN parts are nominally standard parts (so every STi has group N bushes and top hats in the show room!) many manufacturers 'bend' the rules by 'selecting' parts (with the same part number moulded in obviously - LOL) that are made of stiffer rubber and selling them for motorsport use, however as stock parts are eligable for GroupN and have the same PN I know of unscroupulous sellers that sell stock parts as if they were the 'selected' parts.
Simon
2005 Base 2.5x foz
Thank you for the words of advice. Any way to tell the difference?
How much better are they? I could just find some random used stock top hats instead.
Are there any good alternatives to the Group N's at around the same price? I don't think so huh? Other than using camber plates or maybe some Whiteline Max-Cs, I don't see much options that are cost worthy.
'09 STI
You can easily tell Group Ns from stock by gouging the rubber with your finger nail. Stock is like cheese Group N is like a rock. In the U.S. STIs definitely don't come with Group N bushings or mounts. Wish they did.
Depending on spring rates they make a world of difference. Jack up your front end and as you lower it watch how far the top hat moves before the suspension compresses. That's a lot of undamped movement there.
2005 Base 2.5x foz
Discussion Starter · #11 · (Edited)
Yea, dude wont do under $300 shipped. Not worth it.
Are all group n top hats the same for the 04+ or will the STI ones not fit (I know some years had the inverted front struts like 2005 STI)
I found a new set for $130 shipped fronts only! Would that work with STI rear top hats and the WRX strut and STI springs?
Sorry for all the questions, this whole getting my suspension thing has been a rough ride. Just want to be %100 sure they will work!
99 UK S-turbo
Tell you what try reading what I wrote again, then again ten more times if you have to.....yes they do! But not the same part sold specifically for motorsport, it depends on what you mean by 'groupN' (in itself a very open to interpretation wording) if you use the loosest menaing as 'eligeable for use in GroupN for motorsport' then they do, caveat emptor as they say!
Oh and 'rubber' has internal damping, so while its not necesarily desireable, its not undamped!
Simon
'09 STI
I'm sorry, I wasn't talking to you but I did mean Group N as in the kind they sell here in the U.S. as an upgrade from stock which is what the thread is about I thought? English can be a complicated language if you make it so.
04-07 STI ones fit our Foresters. just use them with 04-07 WRX or STI springs. bolt pattern (the three strut bolts that connect the suspension to the body) is the same as 02-03 group Ns--it's just a different spring perch for a different generation of springs. some guys argue all you need is the fronts, so $130 shipped from TIC is pretty good IMO. I can't find any used sets so I will probably just go that direction.
1 - 16 of 16 Posts
