1 - 15 of 15 Posts
2005 Forester 2.5XT 5 Speed Manual
For my SG5 Fozzy I orderd the Grimmspeed master brake cylinder brace to have that extra feel/bite with my OEM disks and HP+ hawk pads.
I don't feel a difference between for and after install.
It only fits with three bolts. Two on the side wear the fuel filter bracket is placed and one where you have to pop out a plastic clip that hold some lines.
As you can see it does block the master cylinder.
In my case just an other hyped thing in forum world.
SG9 Forester XT Stick Shift
OEM pedal travel for some season have too much free play. Adjusting those are the biggest improvement I got from stock brakes. The rod between the pedal and the master cylinder need to be adjusted to give no more than 2-4 mm of free play. Don't forget to adjust the brake light switch too.
http://www.scoobymods.com/showthread.php/adjust-brake-pedal-free-play-7436.html?
This master cylinder brace only noticeable under hard braking when you flex the firewall. I definitely notice difference but not under all circumstances.
How is it brace placed on your car?
On mine I only had three mounting points.
Have you bled your brake system? Do that and I'll bet you will feel a difference. The effect of the master cylinder brace is only really noticeable under heavy braking where the force against the master cylinder causes the brake booster housing to flex.
2014 Forester XT CVT
I noticed a big difference with this. Summer you didn't.
Ditto, I had one of these in my Impreza, it was REALLY noticeable, even to my doubting friend who helped me install it.
Just be careful tightening it, as after a couple years of track days I developed a slow leak between the booster and master cylinder, needed to be replaced. I suspect it was aggravated by the brake brace.
Ofcourse the system was bled.
I think I must brake harder or my master cylinder isn't that bad at all :p
2010 forester x manual
just installed mine on my 2010x. I can honestly say that there is a big difference even under low speed stopping. pedal is much firmer from the get go and this is with no other brake mods. I would say this is a must have to anyone who ummm, well who has driven any other car with power brakes!
good job Grim!
I can say that the cup on mine does not line up perfect with the center of the master cylinder, but there is enough play due to the cup design that it does sit flush.
anyone else with an sh want to chime in?
2011 Forester XT Automatic
I have the MC brace, SS lines, stoptech pads, and motul fluid. HUGE difference compared to stock as the brakes feel significantly more responsive. Also, however much pressure i'm placing on the brakes is equal to the amount of brake pressure on the pads. Before these mods, the forester felt like it had sponges for brakes.
2007 forester xt auto
Seems to me an easy way to see if this works is to have someone pound on the brake pedal and watch for movement of the MC. If it moves the brace will work.
2004 Forester XT 4EAT
Pedal adjustment took about two minutes and feels like new breaks! Stupid easy things that make a world of difference. For street driving.
Still think I'm gonna get the MC brace and do a full sys bleed replacing with some high grade fluid. Always want more stop on the track.
2000 Forester S AT
This part doesn't fix anything if the master cylinder is bad, it is there to keep the firewall from flexing under heavy braking. If you aren't pushing the brake pedal hard enough for the the firewall to flex - that's a good thing.
2010 Forester XT LTD 4EAT
good job Grim!
I've got one on my '10 XT and noticed an immediate improvement for all braking scenarios...
1 - 15 of 15 Posts
