1 - 16 of 16 Posts
Forester X Premium Slushbox
Bought my Forester three weeks or so back, but this last weekend saw the first round of (minor) updates.
The first couple of things were done at Pronto Brake and Muffler in Oxnard, CA (my brother has worked there for years). At some point, a cheap generic replacement muffler had been attached, and the production welds on the muffler itself were starting to crack, making for an annoying rattle at the rear under acceleration. After cutting it off and then holding several different mufflers up to the open pipe, we decided a small two-chamber Flowmaster had the right combination of growl without any harsh noise. It was capped off with a black, angle cut rectangular tip. While it was up on the lift, the broken front swaybar link was also replaced. (Holy crap, it actually corners now!)
After departing Pronto, I backed it up into the driveway at home and replaced the taillights with '08 Sport units. I also popped the door panels loose, replacing the stock speakers with coaxials from Memphis.
522592
Next weekend, Plans are to do the front. The right front headlight is fogging up, so I have a pair of Sport pieces on their way to replace those. While I have the bumper off, I may also do something with the foglights and that grille, too.
522593
That should complete my first round of mods. Next will likely be suspension (Swift/Koni), followed soon after by wheels/tires. I can't tell you guys how much help all of the threads on this forum have been to me so far, from the galleries to muffler sizing for an NA, to sizing on the replacement speakers... Thank you all!
-Dave
Discussion Starter #2
After reading @NinoS ' own build journal for his '05, I feel like a ventilation filter clean/change is also in my immediate future.
Won't have time to do the headlight swap until Sunday, probably. Will post pics after. Swift springs and Koni strut inserts are on their way, so I can likely work on that next weekend.
Stoked!
Swift Springs already arrived, but the strut inserts won't be here until later this week. In the meantime, I pulled the front bumper off, and replaced the leaky headlight assemblies with Sport units.
522756
That took very little time, so next I installed some aftermarket "billet" grilles that I had previously painted black.
522757
With that done, I removed the broken stock foglights, and replaced them with a pair of 3-1/2" projectors. Then it was just a matter of putting it all back on the front of the car.
522758
I am enjoying the less blingy, blacked-out look.
522759
Discussion Starter #7
Doing the Koni inserts and Swift springs. Hardest part so far is drilling out the bottom of the strut housing hole to 1/2".
523141
523142
Discussion Starter #8
Update: Springs and struts installed. Super happy with the setup so far, but may back the front strut valving off a little.
523164
I will say that installing the WRX sized inserts into the Forester strut housings requires an extra 3/4" or so to be trimmed from the tops of the housings, but other than that, the process went pretty much as expected.
Discussion Starter #9
I was working on a bunch of bicycle projects today...
523754
But while I was doing that, I figured paint could be drying. I pulled my C-pillar trims off...
523755
And painted them black.
523756
Discussion Starter #10
My new rolling stock is due to arrive on Thursday. While I have the wheels off, I figured I would install fender braces and saggy butt spacers from Paranoid Fabrications.
524104
2004 Forester XS 5MT
Great build, two questions, how hard were the sail panels to pull, and what kind of bike is that?
Discussion Starter #13
Open the doors, and you can just pop the panels loose with a little pull.
The bike is a Nirve Stilletto. It's a fun ride. 3 speeds, and a disc brake in front to supplement the rear coaster brake.
Thank you, My panels look rough and since I replaced the rear panel under the wiper they jump out, lol! That bike looks super comfortable too! My GF got me back on a mountain bike but the angle bothers my neck, I may look into this one, it has such a cool look to it, I've never seen a bike like it.
Anything new lately? Pulled the sail panels for coating and yeah, cake!
1 - 16 of 16 Posts
