2016 Forester Auto
My 06 Forester's CEL came on the other day so I took it to Autozone to have them read the code.
Came back as Fuel Temperature Sensor (FTS) "A" Circuit Low. After searching around the net I am not finding much on this one.
Does anyone know where this sensor is located? I assume in or around the fuel tank. The car runs fine. Just want to get this resolved so I can use my cruise control again.
Thanks.
2014 Impreza Ltd CVT
Here are a few things that MAY help. P0182 means the ECU is seeing the sensor as SHORTED. So the sensor may be bad, or a wire going to it may be damaged and touching ground.
The sensor itself, you will see, is in the fuel tank and part of the pickup assy.
