I found these tires and they have very good ratings and interesting tire specs. The 215 is the same width as the 225 and weighs 4 pounds less.
here are the specs:
215/55R17
Load Index 94 = 1477lbs (670kg) per tire
Speed Rating “V” = 149mph (240kph) 94V SL Treadwear: 380
Traction: A
Temperature: A380 A A 1477 lbs.
51 psi
10/32"
21lbs. 6-8" approved rim sizes
7"
9.2" "tread width"
NA
26.3" overall diameter
780 revs
Country of Origin "FR"
225/55R17
Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “V” = 149mph (240kph) 97V SL Treadwear: 380
Traction: A
Temperature: A380 A A 1609 lbs.
51 psi
10/32"
25lbs. 6-8" approved rim sizes
7"
9.2" "tread width"
NA
26.7" overall diameter
775 revs
Help me decide. Im running 17X7.5 BBS goldies with stock tires
here are the specs:
215/55R17
Traction: A
51 psi
10/32"
7"
9.2" "tread width"
NA
780 revs
225/55R17
Traction: A
51 psi
10/32"
7"
9.2" "tread width"
NA
775 revs
