Installed the Gauge Pack today. Everything went very well, good instructions, a very straightforward install....until I got to the last blue wire that is supposed to connect to the wiring harness with the little red wire connector :shock:
Good God. Folks, that 24-pole connector is waaaay up in the inards up under the dash. Plus I'm 49, I wear contacts, and it's DANG hard to see, much less pick out the lil green/black wire out of 24 others all bunched together!! I ended up stacking 4 couch cushions up beside the door, laying down on my back with my head jammed in next to the accelerator, looking up. I could barely see, much less get my hands on anything.
Let me tell you, perserverance will move mountains. Somehow, someway....and yes I was at it for a good hour....I got that lil sun of a gun attached to the wire I was PRAYING was black/green. It seemed to match the spot on the diagram so I PRAYED it was correct.
A miracle. It worked. :bananapowerslide:
