1 - 14 of 14 Posts
2018 forester
I recently gas up the brand new 2018 forester and noticed that the gas cap does not click. I unscrewed and screwed it on several times but no clicks at all. All the other times it has clicked. Everything seems tight and clean. Is there a problem? Do I need a new cap?
2017 dark grey metallic
If the gas cap is not sealing properly you would have had a check engine light in short order.. I would not rush to the dealer,but I would check to see if they will replace the cap under warrenty. It is part of the emissions control system.If you do get a check engine light, the engine wil operate run at default values ,not optiumum values and you will wonder if the gas cap is the isssue. Cheers Doug
2018 forester
Unfortunately, I have no confidence in my dealer after a bad experience when they took my car in for a simple service. If anything I would rather buy a new gas cap. Is the part number 42031FJ000 correct? Does anyone know the part number of the plastic clip holding the leash?
2014 Forester 2.5i
for the most i just snug mine up and go. the continuous clickers are to prevent over tightening. i'll have to see what the manual has to say about it.
2018 forester
Discussion Starter · #11 ·
Yes, I would leave it alone if it were a car that is more than three years old but if it is less than 1 year old why has the click mechanism on the gas cap already broke? Subaru's "made in japan" gas caps are that poorly made that they cannot even last a year? Technically, I probably fueled up less than twenty times since my car has less than 3000 miles. There is some sort of manufacturing issue with these gas caps if they cannot last a year.
2015 Forester 2.5 Premium CVT
Do you have a different dealer near you? If not, it may not be a bad idea to go to this dealer anyway, just to get the issue logged - as long as you get the paperwork for your visit.
I guess you could send an email to Subaru customer service to start a paper trail, but they might just tell you to visit the dealer.
Mike
2019 Forester Sport CVT
my Foz's gas cap closes with increasing resistance, but no click. no CELs, no nothing. learned behavior: stop when resistance is there. Don not follow the Borg mantra!
1 - 14 of 14 Posts
